소개
Following this guide will help you remove and replace the motherboard on a Samsung Chromebook 2 XE503c12.
필요한 것
Flip device over so that the underside is facing up.
Remove nine, 7mm PH#0 screws from the bottom.
Locate the motherboard at top right of chromebook.
Remove four 9mm Phillips #0 screws and two 7mm Phillips #0 screws.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
