주요 콘텐츠로 건너뛰기
Samsung Chromebook 2 XE503c12 Motherboard Replacement
필요한 것
  1. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 2 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 3 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: 3 단계, 이미지 2/2
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 5 단계, 이미지 1/1
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • Locate the motherboard at top right of chromebook.
    • Remove four 9mm Phillips #0 screws and two 7mm Phillips #0 screws.
  7. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 7 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: 7 단계, 이미지 2/2
    • Remove auxiliary wires for microphone and webcam.
  8. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 8 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Motherboard Replacement: 8 단계, 이미지 2/2
    • Lift hinge on connector up and pull the connector away from the device.
  9. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 9 단계, 이미지 1/1
    • Remove the connector for the motherboard and sub-board.
  10. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the connector for motherboard and chromebook.
  11. Samsung Chromebook 2 XE503c12 Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the motherboard from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Britney Betterman
회원 가입일: 09/26/18
253 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 505
