주요 콘텐츠로 건너뛰기
Samsung Chromebook 2 XE503c12 Screen Replacement
필요한 것
  1. Samsung Chromebook 2 XE503c12 Screen Replacement, Battery: 1 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Flip device over so that the underside is facing up.
    • Remove nine, 7mm PH#0 screws from the bottom.
  2. Samsung Chromebook 2 XE503c12 Screen Replacement: 2 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Screen Replacement: 2 단계, 이미지 2/2
    • Using the plastic opening tool, pry open the bottom of the Chromebook case, working all around the computer.
    • Lift the panel out of the way to reveal the battery.
  3. Samsung Chromebook 2 XE503c12 Screen Replacement: 3 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Screen Replacement: 3 단계, 이미지 2/2
    • Remove four, 5mm Phillips #0 screws connecting the battery to the laptop
  4. Samsung Chromebook 2 XE503c12 Screen Replacement: 4 단계, 이미지 1/1
    • Lift the battery, and pull it up and towards you, away from the connector.
    • Be sure to lift gently to avoid damage to connector
  5. Samsung Chromebook 2 XE503c12 Screen Replacement: 5 단계, 이미지 1/1
    • Using a plastic opening tool, pry the connector up from the contact.
    • Remove the battery from the device.
  6. Samsung Chromebook 2 XE503c12 Screen Replacement, Screen: 6 단계, 이미지 1/2 Samsung Chromebook 2 XE503c12 Screen Replacement, Screen: 6 단계, 이미지 2/2
    • Remove the four 5mm Phillips #0 screws on the hinges.
  7. Samsung Chromebook 2 XE503c12 Screen Replacement: 7 단계, 이미지 1/3 Samsung Chromebook 2 XE503c12 Screen Replacement: 7 단계, 이미지 2/3 Samsung Chromebook 2 XE503c12 Screen Replacement: 7 단계, 이미지 3/3
    • Unplug two auxiliary wires leading to the top lid.
    • Using the plastic prying tool, lift the hinge on the connector up and pull the connector away.
  8. Samsung Chromebook 2 XE503c12 Screen Replacement: 8 단계, 이미지 1/1
    • Lift the hinges up and separate the top lid from the bottom casing.
  9. Samsung Chromebook 2 XE503c12 Screen Replacement: 9 단계, 이미지 1/3 Samsung Chromebook 2 XE503c12 Screen Replacement: 9 단계, 이미지 2/3 Samsung Chromebook 2 XE503c12 Screen Replacement: 9 단계, 이미지 3/3
    • Using the plastic prying tool, carefully pry the casing apart from the screen.
    • When prying case apart, there is a risk of screen and parts of the casing shattering and cutting you.
  10. Samsung Chromebook 2 XE503c12 Screen Replacement: 10 단계, 이미지 1/1
    • Remove the four 5mm Phillips #0 screws holding the screen in place.
  11. Samsung Chromebook 2 XE503c12 Screen Replacement: 11 단계, 이미지 1/1
    • Lift and remove the screen from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jordan W Jones
회원 가입일: 02/15/18
397 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 434
