주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 Battery Replacement
필요한 것
  1. Samsung Chromebook 3 Battery Replacement, Bottom Case: 1 단계, 이미지 1/2 Samsung Chromebook 3 Battery Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Battery Replacement: 2 단계, 이미지 1/3 Samsung Chromebook 3 Battery Replacement: 2 단계, 이미지 2/3 Samsung Chromebook 3 Battery Replacement: 2 단계, 이미지 3/3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Battery Replacement: 3 단계, 이미지 1/1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Battery Replacement, Battery: 4 단계, 이미지 1/2 Samsung Chromebook 3 Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Battery Replacement: 5 단계, 이미지 1/2 Samsung Chromebook 3 Battery Replacement: 5 단계, 이미지 2/2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Battery Replacement: 6 단계, 이미지 1/1
    • Lift the battery up and out from the case.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Austin Blakely
회원 가입일: 03/11/19
19,506 평판
안내서 53개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 한 개
Can you fix my chromebook
Peter Hancocks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 21
전체 시간: 1,510
