주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 Daughterboard Replacement
필요한 것
  1. Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: 1 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Daughterboard Replacement, Bottom Case: 1 단계, 이미지 2개 중 2개
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Daughterboard Replacement: 2 단계, 이미지 3개 중 1개 Samsung Chromebook 3 Daughterboard Replacement: 2 단계, 이미지 3개 중 2개 Samsung Chromebook 3 Daughterboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Daughterboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Daughterboard Replacement, Battery: 4 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Daughterboard Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Daughterboard Replacement: 5 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Daughterboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Daughterboard Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: 7 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Daughterboard Replacement, Daughterboard: 7 단계, 이미지 2개 중 2개
    • Before you begin the process of removing the daughterboard, you will need to remove the port case. Using a Phillips #00 screwdriver, remove the three 4.6mm screws.
  8. Samsung Chromebook 3 Daughterboard Replacement: 8 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Daughterboard Replacement: 8 단계, 이미지 2개 중 2개
    • Use a spudger to unhook the cable connecter from the speaker cable.
  9. Samsung Chromebook 3 Daughterboard Replacement: 9 단계, 이미지 3개 중 1개 Samsung Chromebook 3 Daughterboard Replacement: 9 단계, 이미지 3개 중 2개 Samsung Chromebook 3 Daughterboard Replacement: 9 단계, 이미지 3개 중 3개
    • Pry the small coaxial cables upwards from the connecters on the wireless chip.
  10. Samsung Chromebook 3 Daughterboard Replacement: 10 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Daughterboard Replacement: 10 단계, 이미지 2개 중 2개
    • Using the Phillips #00, unscrew one 4.6mm screw from the daughterboard.
  11. Samsung Chromebook 3 Daughterboard Replacement: 11 단계, 이미지 3개 중 1개 Samsung Chromebook 3 Daughterboard Replacement: 11 단계, 이미지 3개 중 2개 Samsung Chromebook 3 Daughterboard Replacement: 11 단계, 이미지 3개 중 3개
    • Use a spudger to lift the gray plastic bar on the zif connecter up, then use your fingers to remove the cable ribbon.
  12. Samsung Chromebook 3 Daughterboard Replacement: 12 단계, 이미지 1개 중 1개
    • Loosen the daughterboard from the USB port with a spudger as there is some adhesive underneath, and you're ready to remove the daughterboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Sarah Westberg
회원 가입일: 03/11/19
35,662 평판
안내서 71개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 1,461
