주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 Display Replacement
필요한 것
  1. Samsung Chromebook 3 Display Replacement, Bottom Case: 1 단계, 이미지 1/2 Samsung Chromebook 3 Display Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Display Replacement: 2 단계, 이미지 1/3 Samsung Chromebook 3 Display Replacement: 2 단계, 이미지 2/3 Samsung Chromebook 3 Display Replacement: 2 단계, 이미지 3/3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Display Replacement: 3 단계, 이미지 1/1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Display Replacement, Battery: 4 단계, 이미지 1/2 Samsung Chromebook 3 Display Replacement, Battery: 4 단계, 이미지 2/2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Display Replacement: 5 단계, 이미지 1/2 Samsung Chromebook 3 Display Replacement: 5 단계, 이미지 2/2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Display Replacement: 6 단계, 이미지 1/1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Display Replacement, Display: 7 단계, 이미지 1/3 Samsung Chromebook 3 Display Replacement, Display: 7 단계, 이미지 2/3 Samsung Chromebook 3 Display Replacement, Display: 7 단계, 이미지 3/3
    • Disengage the gold connector joining the display and motherboard by flipping up the hinge with a spudger and gently disconnecting it with a spudger or your fingers.
  8. Samsung Chromebook 3 Display Replacement: 8 단계, 이미지 1/3 Samsung Chromebook 3 Display Replacement: 8 단계, 이미지 2/3 Samsung Chromebook 3 Display Replacement: 8 단계, 이미지 3/3
    • Next disconnect the small coaxial cables from the wireless chip on the daughterboard by prying upwards with a spudger.
  9. Samsung Chromebook 3 Display Replacement: 9 단계, 이미지 1/2 Samsung Chromebook 3 Display Replacement: 9 단계, 이미지 2/2
    • Flip up at least one side of the adhesive tape holding the coaxial cables in place. When the display is removed, the cables are coming with it!
  10. Samsung Chromebook 3 Display Replacement: 10 단계, 이미지 1/2 Samsung Chromebook 3 Display Replacement: 10 단계, 이미지 2/2
    • Finally, remove the four 4.6mm screws from the display mounts using a Phillips #00 screwdriver.
    • It might be easier to open the laptop before removing these screws as the display will only come off while in the open position.
  11. Samsung Chromebook 3 Display Replacement: 11 단계, 이미지 1/1
    • Open the laptop and remove the display.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Austin Blakely
회원 가입일: 03/11/19
19,506 평판
안내서 53개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 3개
Any idea as to what kind of connector the display has to the motherboard? Or how many pins? Trying to tear down the display and see if I can use it as an extra monitor.
Sam Rall - 답글
It looks like there are 40 pins on the display connector. I’m not sure what it would be called or if it’s any kind of standard. If you do manage to convert the display to an extra monitor, you should definitely let us know though!
Austin Blakely -
Great guide - my 12 year old son was able to get through it with a little help from me. Nice work.
smo2 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 1,492
