주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 Motherboard Replacement
필요한 것
  1. Samsung Chromebook 3 Motherboard Replacement, Bottom Case: 1 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Motherboard Replacement, Bottom Case: 1 단계, 이미지 2개 중 2개
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Samsung Chromebook 3 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Samsung Chromebook 3 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Motherboard Replacement, Battery: 4 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Motherboard Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 1개 Samsung Chromebook 3 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 2개 Samsung Chromebook 3 Motherboard Replacement, Motherboard: 7 단계, 이미지 3개 중 3개
    • Before you can get to the motherboard, remove the three 4.6mm screws from the port cover using a Phillips #00 screwdriver.
  8. Samsung Chromebook 3 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Samsung Chromebook 3 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Samsung Chromebook 3 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Then, use a spudger to begin flipping up the grey covers on the ZIF connectors.
  9. Samsung Chromebook 3 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Samsung Chromebook 3 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Samsung Chromebook 3 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • Two more ZIF connectors to go!
  10. Samsung Chromebook 3 Motherboard Replacement: 10 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Motherboard Replacement: 10 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the cables going to the speaker by prying outward to the right.
  11. Samsung Chromebook 3 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Samsung Chromebook 3 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Samsung Chromebook 3 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • Use a spudger to lift the hinge locking the gold colored display cable in place.
    • Then gently coax the display cable from its connector using your fingers or a spudger.
  12. Samsung Chromebook 3 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Samsung Chromebook 3 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Use your Phillips #00 screwdriver to remove four 4.6mm screws from the motherboard.
  13. Samsung Chromebook 3 Motherboard Replacement: 13 단계, 이미지 1개 중 1개
    • Ensure all cables are clear and remove the motherboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Austin Blakely
회원 가입일: 03/11/19
22,286 평판
안내서 53개를 작성함
1가이드 댓글
Thanks for the great guide! I used it to remove the write protection screw on the back of the motherboard.
My Chromebook is model number XE501C13. The only difference I noticed is that there is one less screw on the outer plastic cover. Everything else is exactly the same!
Edward Fernandez - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 38
전체 시간: 3,857
