주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 Speakers Replacement
필요한 것
  1. Samsung Chromebook 3 Speakers Replacement, Bottom Case: 1 단계, 이미지 1/2 Samsung Chromebook 3 Speakers Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Speakers Replacement: 2 단계, 이미지 1/3 Samsung Chromebook 3 Speakers Replacement: 2 단계, 이미지 2/3 Samsung Chromebook 3 Speakers Replacement: 2 단계, 이미지 3/3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Speakers Replacement: 3 단계, 이미지 1/1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Speakers Replacement, Speakers: 4 단계, 이미지 1/2 Samsung Chromebook 3 Speakers Replacement, Speakers: 4 단계, 이미지 2/2
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 Speakers Replacement: 5 단계, 이미지 1/3 Samsung Chromebook 3 Speakers Replacement: 5 단계, 이미지 2/3 Samsung Chromebook 3 Speakers Replacement: 5 단계, 이미지 3/3
    • Remove one 4.9mm silver screw from each speaker with a Phillips #00 screwdriver.
  6. Samsung Chromebook 3 Speakers Replacement: 6 단계, 이미지 1/3 Samsung Chromebook 3 Speakers Replacement: 6 단계, 이미지 2/3 Samsung Chromebook 3 Speakers Replacement: 6 단계, 이미지 3/3
    • Use a plastic spudger to gently coax the cable connecter sideways from the motherboard and the left speaker. When disconnected, remove speaker.
  7. Samsung Chromebook 3 Speakers Replacement: 7 단계, 이미지 1/3 Samsung Chromebook 3 Speakers Replacement: 7 단계, 이미지 2/3 Samsung Chromebook 3 Speakers Replacement: 7 단계, 이미지 3/3
    • Use a plastic spudger to gently disconnect the cable connecter from the daughterboard and the right speaker. Remove the speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sarah Westberg
회원 가입일: 03/11/19
18,850 평판
안내서 68개 작성하였습니다
iFixit iFixit 회원
Community
141 회원들
안내서 17,569개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 456
