주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 XE500C13-K02US Battery Replacement
필요한 것
  1. Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Bottom Case: 1 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Bottom Case: 1 단계, 이미지 2/2
    • Place the laptop back cover facing up to expose the screws.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: 2 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: 2 단계, 이미지 2/2
    • Use an iFixit opening tool to wedge in between the case and body of the laptop.
    • Once the tool is wedged in between the case and laptop, slide it around the entire laptop's edge to disengage the retaining clips.
    • You should hear a popping sound as you slide the iFixit opening tool around the laptop.
  3. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: 3 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: 3 단계, 이미지 2/2
    • Remove the cover exposing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Battery: 4 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the four 4.6mm screws with the Phillips #00 screwdriver.
  5. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: 5 단계, 이미지 1/3 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: 5 단계, 이미지 2/3 Samsung Chromebook 3 XE500C13-K02US Battery Replacement: 5 단계, 이미지 3/3
    • Use the spudger to pry underneath the cable and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K02US Battery Replacement: 6 단계, 이미지 1/1
    • Lift the battery up and out of the case.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mick McCarty
회원 가입일: 03/18/19
980 평판
안내서 6개 작성하였습니다
University of Memphis, Team S1-G24, Kim Spring 2019 University of Memphis, Team S1-G24, Kim Spring 2019 회원
UM-KIM-S19S1G24
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 1,508
