주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement
필요한 것
  1. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: 1 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement, Display Hinges: 1 단계, 이미지 2/2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: 2 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: 2 단계, 이미지 2/2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: 3 단계, 이미지 1/3 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: 3 단계, 이미지 2/3 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: 3 단계, 이미지 3/3
    • Disconnect black and white wire from the I/O board.
    • Remove two 4.6 mm screws from the display hinge using a Phillips #00 screwdriver.
    • Rotate both display hinges upward, away from the components.
  4. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: 4 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: 4 단계, 이미지 2/2
    • Remove the nuts with a 5 mm nut driver socket.
    • Remove all six washers from each side.
  5. Samsung Chromebook 3 XE500C13-K02US Display Hinges Replacement: 5 단계, 이미지 1/1
    • Remove the hinges from the bar on both sides.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Caden Smith
회원 가입일: 03/28/23
397 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-3, Harley Spring 2023 IUPUI, Team 3-3, Harley Spring 2023 회원
IUPUI-HARLEY-S23S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 103
