주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement
필요한 것
  1. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: 1 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement, I/O Board with Integrated Wi-Fi Card: 1 단계, 이미지 2/2
    • Place the laptop back cover facing up to expose all nine 4.6 mm screws.
    • Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
  2. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 2 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 2 단계, 이미지 2/2
    • Wedge a plastic opening tool underneath the cover of the laptop.
    • Once the tool is wedged between the cover and the body of the laptop, slide the tool around the edge of the laptop to disengage the retaining clips.
    • Remove the cover of the laptop to expose the inside components.
  3. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 3 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the three 4.6 mm screws from the silver bracket.
  4. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 4 단계, 이미지 1/1
    • Remove the silver bracket.
  5. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 5 단계, 이미지 1/1
    • Remove the 4.6 mm screw from the I/O board.
  6. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 6 단계, 이미지 1/1
    • Remove the wire connector from the I/O board.
  7. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 7 단계, 이미지 1/1
    • Remove the black and white wires from the I/O board.
  8. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 8 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 8 단계, 이미지 2/2
    • Lift the clip of the ribbon cable connector.
    • Remove the ribbon cable from the I/O board.
  9. Samsung Chromebook 3 XE500C13-K02US I/O Board with Integrated Wi-Fi Card Replacement: 9 단계, 이미지 1/1
    • Lift and remove the I/O board from the base of the laptop
결론
Alex
회원 가입일: 03/28/23
178 평판
안내서 1개 작성함
IUPUI, Team 3-3, Harley Spring 2023 IUPUI, Team 3-3, Harley Spring 2023 회원
IUPUI-HARLEY-S23S3G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 154
