소개
This guide is a step-by-step guide on how to replace the Samsung Chromebook 3 XE500C13-K02US I/O board with integrated Wi-Fi card. You will need to remove the battery, disconnect the I/O board from the motherboard, remove the 2 pins speaker connecter, and the black and white wire running into the hinge cover
필요한 것
Place the laptop back cover facing up to expose all nine 4.6 mm screws.
Remove all nine 4.6 mm screws using a Phillips #00 screwdriver.
거의 끝나갑니다!
결론
