주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 XE500C13-K05US Battery Replacement
필요한 것
  1. Samsung Chromebook 3 XE500C13-K05US Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Place the laptop back cover facing up to show the screws.
    • Use a Phillips #00 screwdriver to remove the nine 4.6 mm bottom cover screws.
  2. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 2 단계, 이미지 1/1
    • Use a nylon spudger or plastic opening tool to pop open the cover of the laptop.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 3 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 3 단계, 이미지 2/2
    • Remove the cover showing the inside of the laptop.
  4. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 4 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 4 단계, 이미지 2/2
    • Unscrew and remove the four screws that secure the battery.
  5. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 5 단계, 이미지 1/3 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 5 단계, 이미지 2/3 Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 5 단계, 이미지 3/3
    • Use a spudger to pry underneath the battery cable connector, and gently lift the connector up.
  6. Samsung Chromebook 3 XE500C13-K05US Battery Replacement: 6 단계, 이미지 1/1
    • Lift the battery out of the case to remove it from the laptop.
결론
Yamaris Acosta
회원 가입일: 02/07/23
557 평판
안내서 3개 작성하였습니다
Gateway, Team 4-4, Gonzalez Spring 2023 Gateway, Team 4-4, Gonzalez Spring 2023 회원
GCC-GONZALEZ-S23S4G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 22
전체 시간: 177
