주요 콘텐츠로 건너뛰기
Samsung Chromebook 3 XE500C13-K05US Speaker Replacement
필요한 것
  1. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Place the Chromebook face down so the bottom case is uncovered.
    • Use the Phillips #00 screwdriver to remove all nine 4.6mm screws from the back case.
  2. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 2 단계, 이미지 1/1
    • Use a nylon spudger or plastic opening tool to pry the case up from the vent on the hinge side of the Chromebook.
    • You will hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 3 단계, 이미지 1/1
    • Raise the case up and off the device.
  4. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 4 단계, 이미지 1/3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 4 단계, 이미지 2/3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 4 단계, 이미지 3/3
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 5 단계, 이미지 1/3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 5 단계, 이미지 2/3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 5 단계, 이미지 3/3
    • Remove one 4.9mm silver screw from each speaker.
  6. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 6 단계, 이미지 1/3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 6 단계, 이미지 2/3 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 6 단계, 이미지 3/3
    • Use a spudger to gently push the cable connector sideways from the motherboard and the left speaker to disconnect the cable.
    • Remove the speaker.
  7. Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 7 단계, 이미지 1/2 Samsung Chromebook 3 XE500C13-K05US Speaker Replacement: 7 단계, 이미지 2/2
    • Use a spudger to gently push the cable connector sideways from the motherboard and the right speaker to disconnect the cable.
결론
Yamaris Acosta
회원 가입일: 02/07/23
557 평판
안내서 3개 작성하였습니다
Gateway, Team 4-4, Gonzalez Spring 2023 Gateway, Team 4-4, Gonzalez Spring 2023 회원
GCC-GONZALEZ-S23S4G4
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 58
