주요 콘텐츠로 건너뛰기
Samsung Chromebook Plus Battery Replacement
필요한 것
  1. Samsung Chromebook Plus Battery Replacement, Removing back panel screws: 1 단계, 이미지 1/1
    • Remove the 8 PHILIPS#0 screws
  2. Samsung Chromebook Plus Battery Replacement, Removing back panel: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Stick a plastic card (or fingernail) into the gap between panel and the body. Then lift the panel up (long side with speakers closest).
  3. Samsung Chromebook Plus Battery Replacement, Removing battery screws: 3 단계, 이미지 1/1
    • Use your PHILIPS#0 and remove the 4 screws
  4. Samsung Chromebook Plus Battery Replacement, Removing the battery: 4 단계, 이미지 1/1
    • Lift battery from bottom side first (marked with red line)
  5. Samsung Chromebook Plus Battery Replacement, Finally detaching the battery: 5 단계, 이미지 1/1
    • Detach battery cable grabbing the side and pulling the cable upward.
  6. Samsung Chromebook Plus Battery Replacement, Inserting the new battery: 6 단계, 이미지 1/1
    • Insert the battery and push the plug into the socket downward.
  7. Samsung Chromebook Plus Battery Replacement, Re-inserting the screws: 7 단계, 이미지 1/1
    • Re-insert the screws in the holes circled red (on this image), which is where you removed them previously.
  8. Samsung Chromebook Plus Battery Replacement, The back panel gets re-inserted: 8 단계, 이미지 1/1
    • Insert the hinge-side middle screw (must be done first otherwise casing may bulge) and insert rest of panel. On the hinge side, press down on the sides (if there is bulging) until you hear it snap. Insert the two other hinge-side screws (marked with orange on image). After that, insert the other 5 screws (yellow).
    Excellent tutorial! Replaced the batt on our Samsung Chromebook plus circa 2017-18. Ordered batt from seller on Ebay of new old stock. Thanks so much!
    H Brill - 답글
결론
To reassemble your device, skip steps 1-5.
다른 7명이 해당 안내서를 완성하였습니다.
Evan Elm
회원 가입일: 12/31/17
1,023 평판
안내서 3개 작성하였습니다
Kid fixers Kid fixers 회원
Community
156 회원들
안내서 292개 작성하였습니다
댓글 6개
Great repair guide. Nice to see how easy it is to replace battery.
N ick - 답글
Does anyone know where you can get a replacement battery?
Stanley Fujimoto - 답글
Sadly no, I have no idea, chromebookparts.com doesn't have a part either, haven't found one anywhere yet
Evan Elm -
I managed to find a replacement part, see the parts section at the top of the guide :)
Evan Elm -
thanks for finding the battery part! Awesome job!
JT Cen - 답글
Fantastic guide, This made it so easy, especially the note on the cable which clicks in. Thank you so much for sharing.
Morten Damm - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 50
전체 시간: 6,817
