주요 콘텐츠로 건너뛰기
Samsung Chromebook Series 3 Battery Replacement
필요한 것
  1. Samsung Chromebook Series 3 Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Battery Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Battery Replacement: 2 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Battery Replacement: 2 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Battery Replacement: 3 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Battery Replacement: 3 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Battery Replacement: 4 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Battery Replacement: 4 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Battery Replacement, Battery: 5 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Battery Replacement, Battery: 5 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Battery Replacement, Battery: 5 단계, 이미지 3개 중 3개
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Battery Replacement: 6 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Battery Replacement: 6 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Battery Replacement: 7 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • You can now remove the battery.
결론
다른 26명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Andrey Radchishin
회원 가입일: 01/21/15
1,860 평판
안내서 4개를 작성함
UWT Liner: Group 1 UWT Liner: Group 1 회원
Community
5 회원들
안내서 8개를 작성함
댓글 7개
I have replaced my battery 2x and I can not charge them. They work when I get them and they keep the charge while it’s plugged in, but will not increase the charge . Any ideas what I can do?
nier101 - 답글
It could be the AC power adapter is not functioning correctly. You may want to double check the charging port, too. (Samsung Chromebook Series 3 Charging Port Replacement)
Jorge Gomes -
I had a similar problem and it turned out I had not properly attached the battery connector -- the instruction is a little misleading. You do have to get those pins into the connector, which requires some horizontal movement. Here's a cute trick: plug in the AC adapter before you plug in the battery (and with the back still off -- plug in the AC directly, not through the hole in the case.) Because the battery is not connected, you'll see the green light. When you've made the connection, charging will begin and the light will change to yellow. So just fiddle -- gently -- with the battery connector until you see that yellow.
Clifford Story -
As an aside… When removing the back, the little spring-loaded “door” came loose and fell out before I was able to see how it was attached. I figured it out, but would love to have additional instructions for items such as this. I didn’t find a teardown for this model, but will keep looking.
Thanks for this contribution.
Joan Clark - 답글
The entire process was much simpler than I had imagined it would be. I was a little concerned about applying a lot of pressure to remove some of the screws. Otherwise, it came apart like the back of a cell phone, and pushed back together just as easily. Anyone know of a worth while battery recycling center?
Laro Nicol - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 92
전체 시간: 12,009
