주요 콘텐츠로 건너뛰기
Samsung Chromebook Series 3 Bottom Cover Replacement
필요한 것
  1. Samsung Chromebook Series 3 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 1/3 Samsung Chromebook Series 3 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 2/3 Samsung Chromebook Series 3 Bottom Cover Replacement, Bottom Cover: 1 단계, 이미지 3/3
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Bottom Cover Replacement: 2 단계, 이미지 1/3 Samsung Chromebook Series 3 Bottom Cover Replacement: 2 단계, 이미지 2/3 Samsung Chromebook Series 3 Bottom Cover Replacement: 2 단계, 이미지 3/3
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Bottom Cover Replacement: 3 단계, 이미지 1/3 Samsung Chromebook Series 3 Bottom Cover Replacement: 3 단계, 이미지 2/3 Samsung Chromebook Series 3 Bottom Cover Replacement: 3 단계, 이미지 3/3
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Bottom Cover Replacement: 4 단계, 이미지 1/3 Samsung Chromebook Series 3 Bottom Cover Replacement: 4 단계, 이미지 2/3 Samsung Chromebook Series 3 Bottom Cover Replacement: 4 단계, 이미지 3/3
    • Pry off the bottom cover using a plastic opening tool.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Andrey Radchishin
회원 가입일: 01/21/15
1,860 평판
안내서 4개 작성하였습니다
UWT Liner: Group 1 UWT Liner: Group 1 회원
Community
5 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 87
전체 시간: 6,077
