주요 콘텐츠로 건너뛰기
Samsung Chromebook Series 3 Charging Port Replacement
필요한 것
  1. Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Charging Port Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Charging Port Replacement: 2 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Charging Port Replacement: 2 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Charging Port Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Charging Port Replacement: 3 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Charging Port Replacement: 3 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Charging Port Replacement: 3 단계, 이미지 3개 중 3개
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Charging Port Replacement: 4 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Charging Port Replacement: 4 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Charging Port Replacement: 4 단계, 이미지 3개 중 3개
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: 5 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: 5 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Charging Port Replacement, Charging Port: 5 단계, 이미지 3개 중 3개
    • Unscrew the 3.4 mm screw holding down the charging port module using a Phillips #00 screwdriver.
  6. Samsung Chromebook Series 3 Charging Port Replacement: 6 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Charging Port Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the metal cover above the charging port module by pulling up and moving it slightly left.
  7. Samsung Chromebook Series 3 Charging Port Replacement: 7 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Charging Port Replacement: 7 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Charging Port Replacement: 7 단계, 이미지 3개 중 3개
    • Pull out the charging port module connector by pulling directly up on it.
    • When reassembling, reconnect by positioning the connector directly above its original position and pushing down.
  8. Samsung Chromebook Series 3 Charging Port Replacement: 8 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Charging Port Replacement: 8 단계, 이미지 2개 중 2개
    • You can now pull out the charging port module.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Andrey Radchishin
회원 가입일: 01/21/15
1,860 평판
안내서 4개를 작성함
UWT Liner: Group 1 UWT Liner: Group 1 회원
Community
5 회원들
안내서 8개를 작성함
댓글 2개
What is the reference number for this charging port?
How to find it on ebay/other?
rafal - 답글
If you search "Samsung Chromebook XE303C12" together with "Charge Port" or "Charging Port" or "DC Jack" you should be able to find it! :)
Andrey Radchishin -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 17,752
