주요 콘텐츠로 건너뛰기
Samsung Chromebook Series 3 Front Camera Replacement
필요한 것
  1. Samsung Chromebook Series 3 Front Camera Replacement, Screen: 1 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Front Camera Replacement, Screen: 1 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Front Camera Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Use the iFixit opening tool to get under the front cover and pop it out of place
  2. Samsung Chromebook Series 3 Front Camera Replacement: 2 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Front Camera Replacement: 2 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Front Camera Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four 2.9 mm screws with the Phillips #00 Screwdriver bit.
    • Using the iFixit opening tool, try to lift up the screen (it is held down by some adhesive).
  3. Samsung Chromebook Series 3 Front Camera Replacement: 3 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Front Camera Replacement: 3 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Front Camera Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the lever to release the cable and pull the cable out.
  4. Samsung Chromebook Series 3 Front Camera Replacement: 4 단계, 이미지 1개 중 1개
    • You can now remove the screen.
  5. Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: 5 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: 5 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Front Camera Replacement, Front Camera: 5 단계, 이미지 3개 중 3개
    • Disconnect the ribbon cable connected to the front camera assembly.
    • You will need to flip up the little black lever to release the cable.
  6. Samsung Chromebook Series 3 Front Camera Replacement: 6 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Front Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Use an iFixit opening tool to pry the front camera assembly from the adhesive holding it in place.
결론
작성자
1다른 기여자 명과 함께
Tyler Schultz
회원 가입일: 03/25/19
630 평판
안내서 3개를 작성함
IUPUI, Team S2-G1, Henning Spring 2019 IUPUI, Team S2-G1, Henning Spring 2019 회원
IUPUI-HENNING-S19S2G1
3 회원들
안내서 6개를 작성함
댓글 한 개
Thanks for posting this! I looked all over youtube and couldn’t find anything so I am relieved to find this tutorial! I haven’t performed the repair yet, but I was wondering if removing the screen is necessary. From what I see, I can access the camera by just removing the bezel. Thanks for your feedback in advance!
Angel Knepper - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 439
