주요 콘텐츠로 건너뛰기
Samsung Chromebook Series 3 Motherboard Replacement
필요한 것
  1. Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Motherboard Replacement: 4 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 4 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Motherboard Replacement, Battery: 5 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement, Battery: 5 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement, Battery: 5 단계, 이미지 3개 중 3개
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement, Motherboard: 8 단계, 이미지 3개 중 3개
    • Unscrew the four 3.1 mm screws holding the motherboard with a Phillips #00 screwdriver.
  9. Samsung Chromebook Series 3 Motherboard Replacement: 9 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 9 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement: 9 단계, 이미지 3개 중 3개
    • The audio cable can be removed by simply pulling gently.
    • Use the iFixit opening tool to pop out the 2 antennae lines from the motherboard.
    • When reinstalling these Wifi Antenna connections, align the antenna on top of the fitting and gently use the Plastic Spudger to apply pressure and seat the connection. Do not use your fingers to press down on the connector, or you risk permanently damaging the connector by bending it.
  10. Samsung Chromebook Series 3 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Now, disconnect the keyboard and trackpad ribbon cables.
    • This requires lifting the lever securing the cables to free them, and then gently pulling them out.
  11. Samsung Chromebook Series 3 Motherboard Replacement: 11 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 11 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Motherboard Replacement: 11 단계, 이미지 3개 중 3개
    • The screen cable is secure in place by a lever. Lift the lever to release it, then gently pull it out.
  12. Samsung Chromebook Series 3 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • This cable comes out by just pulling gently.
  13. Samsung Chromebook Series 3 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Lift the motherboard out of place and pull out the CMOS battery cable.
  14. Samsung Chromebook Series 3 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Finally, remove the three 3.1 mm screws with the Phillips #00 screwdriver to remove the plastic cover and completely free the motherboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Tyler Schultz
회원 가입일: 03/25/19
630 평판
안내서 3개를 작성함
IUPUI, Team S2-G1, Henning Spring 2019 IUPUI, Team S2-G1, Henning Spring 2019 회원
IUPUI-HENNING-S19S2G1
3 회원들
안내서 6개를 작성함
1가이드 댓글
One other thing I thought I'd add is if you're doing this and get to as far as removing the motherboard, personally after removing the plastic cover I'd also replace the thermal paste and re-paste the CPU (grey paste you can see smothered between the chip and the plastic/metal heat spreader). Something like PTM7950 would be good in this use case, and saves you having to do it later on as well/better performance and longevity :)
Aadi Bhamidipati - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 36
전체 시간: 2,156
