주요 콘텐츠로 건너뛰기
Samsung Chromebook Series 3 Speaker Replacement
필요한 것
  1. Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: 1 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: 1 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement, Bottom Cover: 1 단계, 이미지 3개 중 3개
    • Lay the Chromebook down so that the bottom cover is facing up.
    • Remove the rubber feet on the four corners of the Chromebook in order to get to the screws underneath. They are stuck on with an adhesive.
  2. Samsung Chromebook Series 3 Speaker Replacement: 2 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 2 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the nine 4.7 mm screws on the bottom cover using a Phillips #00 screwdriver.
  3. Samsung Chromebook Series 3 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Pry up the plastic strip on the back of the Chromebook using a plastic opening tool.
    • It is not necessary to remove it completely. It just needs to be separated from the bottom cover.
  4. Samsung Chromebook Series 3 Speaker Replacement: 4 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 4 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Pry off the bottom cover using a plastic opening tool.
  5. Samsung Chromebook Series 3 Speaker Replacement, Battery: 5 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement, Battery: 5 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement, Battery: 5 단계, 이미지 3개 중 3개
    • Remove six 3.5 mm screws holding the battery using a Phillips #00 screwdriver.
    • Pull out the battery partway in order to easily get to the battery connector.
  6. Samsung Chromebook Series 3 Speaker Replacement: 6 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 6 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement: 6 단계, 이미지 3개 중 3개
    • Disconnect the battery connector by pulling straight up at its base.
    • When reassembling, simply position the connector above it's original place, and push down.
  7. Samsung Chromebook Series 3 Speaker Replacement: 7 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • You can now remove the battery.
  8. Samsung Chromebook Series 3 Speaker Replacement, Speaker: 8 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement, Speaker: 8 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement, Speaker: 8 단계, 이미지 3개 중 3개
    • Disconnect the cable connecting the speakers to the motherboard by pulling on it away from the motherboard.
  9. Samsung Chromebook Series 3 Speaker Replacement: 9 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 9 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement: 9 단계, 이미지 3개 중 3개
    • Lift up the piece of tape covering the trackpad ribbon cable.
    • Lift up the lock on the trackpad ribbon cable using a plastic opening tool.
    • Disconnect the trackpad ribbon cable by pulling it out.
  10. Samsung Chromebook Series 3 Speaker Replacement: 10 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 10 단계, 이미지 2개 중 2개
    • Lift up the trackpad ribbon cable so that it is not covering the speaker wire.
    • Lift up the two pieces of metallic tape so that they no longer cover the speaker wire.
    • When reassembling the device, make sure to lay down the metallic tape in the same place it was prior to disassembly. The tape serves as a connector for certain electrical circuits that should not be disconnected.
  11. Samsung Chromebook Series 3 Speaker Replacement: 11 단계, 이미지 3개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 11 단계, 이미지 3개 중 2개 Samsung Chromebook Series 3 Speaker Replacement: 11 단계, 이미지 3개 중 3개
    • Unscrew the four 3.7 mm screws holding down the speakers using a Phillips #00 screwdriver.
  12. Samsung Chromebook Series 3 Speaker Replacement: 12 단계, 이미지 2개 중 1개 Samsung Chromebook Series 3 Speaker Replacement: 12 단계, 이미지 2개 중 2개
    • Pull the speakers up to remove them.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Andrey Radchishin
회원 가입일: 01/21/15
1,860 평판
안내서 4개를 작성함
UWT Liner: Group 1 UWT Liner: Group 1 회원
Community
5 회원들
안내서 8개를 작성함
댓글 한 개
Many thanks.
Excellent guide .
Triumph Trident - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 1,636
