주요 콘텐츠로 건너뛰기
Samsung Chromebook XE500C21-A03US Keyboard Replacement
필요한 것
  1. Samsung Chromebook XE500C21-A03US Keyboard Replacement, Back Cover: 1 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Back Cover: 1 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Back Cover: 1 단계, 이미지 3/3
    • Turn the power off before beginning this step.
    • Most Chromebooks contain rubber circle pads on each of the four corners to cover the screws. In order to remove the rubber pads, simply use any opening tool.
    • Lay the Chromebook down so that the bottom cover is facing upward.
    • Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
  2. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 2 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 2 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 2 단계, 이미지 3/3
    • Place the opening tool in the divot between the spine of the Chromebook and the back cover.
    • Slowly glide and push down the end of the opening tool along all sides of the Chromebook to detach the brackets. You will hear the brackets detach.
  3. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 3 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 3 단계, 이미지 2/2
    • Using the opening tool, pry off the back cover of the Chromebook
    • Be gentle while prying to avoid breaking the back cover.
  4. Samsung Chromebook XE500C21-A03US Keyboard Replacement, Speakers: 4 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Speakers: 4 단계, 이미지 2/2
    • Use a blunt precision tweezer to remove the speaker cord from the R.A.M.
  5. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 5 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 5 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 5 단계, 이미지 3/3
    • Use the prying tool to find the divot then slowly add pressure until the speaker pops out.
    • Gently lift and remove the speaker from the Chromebook.
  6. Samsung Chromebook XE500C21-A03US Keyboard Replacement, Battery: 6 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Battery: 6 단계, 이미지 2/2
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  7. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 7 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 7 단계, 이미지 2/2
    • Carefully lift the top of the battery then pull it away from you to remove it.
    • Some batteries may be attached via a battery connector. Disconnect the battery connector by simply pulling straight up at its base.
  8. Samsung Chromebook XE500C21-A03US Keyboard Replacement, RAM: 8 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement, RAM: 8 단계, 이미지 2/2
    • Use a blunt precision tweezer to remove the speaker cord from the RAM
  9. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 9 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 9 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, remove all six 2.5 mm screws .
    • Start removing the screws from the wifi card.
  10. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 10 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 10 단계, 이미지 2/2
    • Gently lift the bottom of the wifi card then pull it towards you to disconnect it from the socket.
    • Our Chromebook does not have a circuit board. Remove all units connected to the circuit board if necessary.
  11. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 11 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 11 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 11 단계, 이미지 3/3
    • Gently lift the top left corner of the RAM and pull upward to remove it from the Chromebook.
  12. Samsung Chromebook XE500C21-A03US Keyboard Replacement, SD Card Reader: 12 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement, SD Card Reader: 12 단계, 이미지 2/2
    • Remove both 3 mm screws using a Phillips #000 screwdriver.
  13. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 13 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 13 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 13 단계, 이미지 3/3
    • Remove the yellow tape on the left ribbon cable with a spudger.
    • Use a blunt precision tweezer to remove both ribbon cables attached to the SD card reader.
  14. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 14 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 14 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 14 단계, 이미지 3/3
    • Gently lift the top portion of the SD card reader and pull it away from you to remove it.
    • To reassemble, first insert the bottom of the SD card reader then carefully push downward.
  15. Samsung Chromebook XE500C21-A03US Keyboard Replacement, Keyboard: 15 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Keyboard: 15 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement, Keyboard: 15 단계, 이미지 3/3
    • Using a blunt precision tweezer, pull the white wire off the wificard.
    • Repeat step to remove the black wire to detach the wificard.
  16. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 16 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 16 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 16 단계, 이미지 3/3
    • Using the Phillips #00 screwdriver, remove all six 3.5 mm screws to detach the hinges from the keyboard.
    • The Chromebook displayed does not have all six screws.
  17. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 17 단계, 이미지 1/2 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 17 단계, 이미지 2/2
    • Using the plastic spudger, place it under the hinge and pry it open.
    • Use your hand to lift the hinge.
    • Repeat on other side.
  18. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 18 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 18 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 18 단계, 이미지 3/3
    • Rotate the Chromebook 180 degrees so that the spine and hinges are facing you.
    • Lift the keyboard and trackpad upward.
  19. Samsung Chromebook XE500C21-A03US Keyboard Replacement: 19 단계, 이미지 1/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 19 단계, 이미지 2/3 Samsung Chromebook XE500C21-A03US Keyboard Replacement: 19 단계, 이미지 3/3
    • Pull the keyboard and trackpad away from you to detach them from the spine of the Chromebook.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alexandria Raessner
회원 가입일: 09/11/17
138 평판
안내서 1개 작성함
CSU Fullerton, Team S2-G5, Bruce Fall 2017 CSU Fullerton, Team S2-G5, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G5
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 8
전체 시간: 1,815
