소개
A fast and simple guide to replace the keyboard to your Chromebook.
필요한 것
Lay the Chromebook down so that the bottom cover is facing upward.
Using a Phillips #00 screwdriver, remove all seven 5.5 mm screws from the back cover.
Using a blunt precision tweezer, pull the white wire off the wificard.
Repeat step to remove the black wire to detach the wificard.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
