소개
Replace the back panel on a Chromebook XE550C22.
  1. Turn the power off before beginning this step. Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop. Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Remove the eight 7mm screws using the J0 Screwdriver. Remove the eight 7mm screws using the J0 Screwdriver.
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop. Continue prying around the sides to release more brackets. Continue prying around the sides to release more brackets.
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  5. After deconnecting all the brackets, pull the back panel away from the laptop. Note: The back panel has some flex to it, don't be afraid to use some force.
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Brenna Wolfe
회원 가입일: 2017년 09월 11일
517 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G7
3 회원들
안내서 7개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 111
