주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Replace a faulty or broken battery on a Chromebook XE550C22.
부품
지정된 부품이 없습니다.
  1. Turn the power off before beginning this step. Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop. Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Remove the eight 7mm screws using the J0 Screwdriver. Remove the eight 7mm screws using the J0 Screwdriver.
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. OPEN ALL THE TABS
    RAM Upgrade Kits for Mac
    키트 쇼핑하기
    Enough RAM
    For All The Tabs
    키트 쇼핑하기
  4. Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop. Continue prying around the sides to release more brackets. Continue prying around the sides to release more brackets.
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  5. After deconnecting all the brackets, pull the back panel away from the laptop. Note: The back panel has some flex to it, don't be afraid to use some force.
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  6. Remove the four 3mm screws holding the battery with the J0 screwdriver. Remove the four 3mm screws holding the battery with the J0 screwdriver.
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  7. Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop. Do not lift the battery straight up. This will damage the battery's connectors.
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brenna Wolfe
회원 가입일: 2017년 09월 11일
526 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G7
3 회원들
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 297
