메인 컨텐츠로 가기
소개
This guide will help you remove a bad SSD. The SSD is the main location that your Chromebook stores all important information such as the operating system.
부품
지정된 부품이 없습니다.
  1. Turn the power off before beginning this step. Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop. Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Remove the eight 7mm screws using the J0 Screwdriver. Remove the eight 7mm screws using the J0 Screwdriver.
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop. Continue prying around the sides to release more brackets. Continue prying around the sides to release more brackets.
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  5. After deconnecting all the brackets, pull the back panel away from the laptop. Note: The back panel has some flex to it, don't be afraid to use some force.
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  6. Remove the four 3mm screws holding the battery with the J0 screwdriver. Remove the four 3mm screws holding the battery with the J0 screwdriver.
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  7. Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop. Do not lift the battery straight up. This will damage the battery's connectors.
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  8. Locate the SSD in the center of the Chromebook.
    • Locate the SSD in the center of the Chromebook.
  9. Remove the single 3.5mm screw using the J0 screwdriver. The SSD should "pop-up" on its own after it's unscrewed. The SSD should "pop-up" on its own after it's unscrewed.
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  10. Pull the SSD up and away from the Chromebook Pull the SSD up and away from the Chromebook
    • Pull the SSD up and away from the Chromebook
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Abel Osorio
회원 가입일: 2017년 09월 11일
252 Reputation
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G7
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
Hello where can I get I higher SSD to buy
aduboa moses - 답글
댓글 쓰기
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 28
All Time: 733
