이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
Continue prying around the sides to release more brackets.
After deconnecting all the brackets, pull the back panel away from the laptop.
Remove the four 3mm screws holding the battery with the J0 screwdriver.
Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 4개
Hello where can I get I higher SSD to buy
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
