주요 콘텐츠로 건너뛰기
Samsung Chromebook XE550C22 Wifi Card Replacement
필요한 것
  1. Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: 1 단계, 이미지 1/3 Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: 1 단계, 이미지 2/3 Samsung Chromebook XE550C22 Wifi Card Replacement, Back Panel: 1 단계, 이미지 3/3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook XE550C22 Wifi Card Replacement: 2 단계, 이미지 1/2 Samsung Chromebook XE550C22 Wifi Card Replacement: 2 단계, 이미지 2/2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook XE550C22 Wifi Card Replacement: 3 단계, 이미지 1/3 Samsung Chromebook XE550C22 Wifi Card Replacement: 3 단계, 이미지 2/3 Samsung Chromebook XE550C22 Wifi Card Replacement: 3 단계, 이미지 3/3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook XE550C22 Wifi Card Replacement: 4 단계, 이미지 1/2 Samsung Chromebook XE550C22 Wifi Card Replacement: 4 단계, 이미지 2/2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook XE550C22 Wifi Card Replacement, Battery: 5 단계, 이미지 1/2 Samsung Chromebook XE550C22 Wifi Card Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook XE550C22 Wifi Card Replacement: 6 단계, 이미지 1/2 Samsung Chromebook XE550C22 Wifi Card Replacement: 6 단계, 이미지 2/2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook XE550C22 Wifi Card Replacement, Wifi Card: 7 단계, 이미지 1/1
    • Locate the wifi card on the top left of the Chromebook.
  8. Samsung Chromebook XE550C22 Wifi Card Replacement: 8 단계, 이미지 1/3 Samsung Chromebook XE550C22 Wifi Card Replacement: 8 단계, 이미지 2/3 Samsung Chromebook XE550C22 Wifi Card Replacement: 8 단계, 이미지 3/3
    • Use only plastic tools for this step.
    • Use the spudger to detach the black and white cords from the wifi card.
  9. Samsung Chromebook XE550C22 Wifi Card Replacement: 9 단계, 이미지 1/3 Samsung Chromebook XE550C22 Wifi Card Replacement: 9 단계, 이미지 2/3 Samsung Chromebook XE550C22 Wifi Card Replacement: 9 단계, 이미지 3/3
    • Remove the 6mm screw from the top right corner of the card using the J0 screwdriver.
    • The wifi card will "pop-up".
  10. Samsung Chromebook XE550C22 Wifi Card Replacement: 10 단계, 이미지 1/2 Samsung Chromebook XE550C22 Wifi Card Replacement: 10 단계, 이미지 2/2
    • Using your hands, gently remove the card up and away from the Chromebook.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Linh Luu
회원 가입일: 09/11/17
312 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G7
3 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 36
전체 시간: 3,986
