주요 콘텐츠로 건너뛰기
Samsung Chromebook series 5 XE550C22 SSD Replacement
필요한 것
  1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook series 5 XE550C22 SSD Replacement: 2 단계, 이미지 2개 중 1개 Samsung Chromebook series 5 XE550C22 SSD Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook series 5 XE550C22 SSD Replacement: 3 단계, 이미지 3개 중 1개 Samsung Chromebook series 5 XE550C22 SSD Replacement: 3 단계, 이미지 3개 중 2개 Samsung Chromebook series 5 XE550C22 SSD Replacement: 3 단계, 이미지 3개 중 3개
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook series 5 XE550C22 SSD Replacement: 4 단계, 이미지 2개 중 1개 Samsung Chromebook series 5 XE550C22 SSD Replacement: 4 단계, 이미지 2개 중 2개
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: 5 단계, 이미지 2개 중 1개 Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: 5 단계, 이미지 2개 중 2개
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook series 5 XE550C22 SSD Replacement: 6 단계, 이미지 2개 중 1개 Samsung Chromebook series 5 XE550C22 SSD Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook series 5 XE550C22 SSD Replacement, SSD: 7 단계, 이미지 1개 중 1개
    • Locate the SSD in the center of the Chromebook.
  8. Samsung Chromebook series 5 XE550C22 SSD Replacement: 8 단계, 이미지 3개 중 1개 Samsung Chromebook series 5 XE550C22 SSD Replacement: 8 단계, 이미지 3개 중 2개 Samsung Chromebook series 5 XE550C22 SSD Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  9. Samsung Chromebook series 5 XE550C22 SSD Replacement: 9 단계, 이미지 2개 중 1개 Samsung Chromebook series 5 XE550C22 SSD Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the SSD up and away from the Chromebook
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Abel Osorio
회원 가입일: 09/11/17
330 평판
안내서 2개를 작성함
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G7
3 회원들
안내서 14개를 작성함
5가이드 댓글
Hello where can I get I higher SSD to buy
aduboa moses - 답글
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
frontiergds - 답글
If you want to get more storage out of your chromebook get a sd card and you will only need it if you have a chrultrabook.
Will F - 답글
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
coldspring21 - 답글
You have instructions for model XE520QB?
Jimmy Soon - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 59
전체 시간: 5,782
