주요 콘텐츠로 건너뛰기
Samsung Chromebook series 5 XE550C22 SSD Replacement
필요한 것
  1. Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 1 단계, 이미지 1/3 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 1 단계, 이미지 2/3 Samsung Chromebook series 5 XE550C22 SSD Replacement, Back Panel: 1 단계, 이미지 3/3
    • Turn the power off before beginning this step.
    • Using the spudger, remove the four 1/2 inch skid pads from the back of the laptop.
  2. Samsung Chromebook series 5 XE550C22 SSD Replacement: 2 단계, 이미지 1/2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 2 단계, 이미지 2/2
    • Remove the eight 7mm screws using the J0 Screwdriver.
  3. Samsung Chromebook series 5 XE550C22 SSD Replacement: 3 단계, 이미지 1/3 Samsung Chromebook series 5 XE550C22 SSD Replacement: 3 단계, 이미지 2/3 Samsung Chromebook series 5 XE550C22 SSD Replacement: 3 단계, 이미지 3/3
    • Starting at the center front of the laptop, insert the metal spudger between the keyboard panel and the bottom panel, separating the bottom panel from the laptop.
    • Continue prying around the sides to release more brackets.
  4. Samsung Chromebook series 5 XE550C22 SSD Replacement: 4 단계, 이미지 1/2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 4 단계, 이미지 2/2
    • After deconnecting all the brackets, pull the back panel away from the laptop.
    • Note: The back panel has some flex to it, don't be afraid to use some force.
  5. Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: 5 단계, 이미지 1/2 Samsung Chromebook series 5 XE550C22 SSD Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the four 3mm screws holding the battery with the J0 screwdriver.
  6. Samsung Chromebook series 5 XE550C22 SSD Replacement: 6 단계, 이미지 1/2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 6 단계, 이미지 2/2
    • Lift the battery up at an angle to disconnect the battery from the motherboard, then pull it away from the laptop.
    • Do not lift the battery straight up. This will damage the battery's connectors.
  7. Samsung Chromebook series 5 XE550C22 SSD Replacement, SSD: 7 단계, 이미지 1/1
    • Locate the SSD in the center of the Chromebook.
  8. Samsung Chromebook series 5 XE550C22 SSD Replacement: 8 단계, 이미지 1/3 Samsung Chromebook series 5 XE550C22 SSD Replacement: 8 단계, 이미지 2/3 Samsung Chromebook series 5 XE550C22 SSD Replacement: 8 단계, 이미지 3/3
    • Remove the single 3.5mm screw using the J0 screwdriver.
    • The SSD should "pop-up" on its own after it's unscrewed.
  9. Samsung Chromebook series 5 XE550C22 SSD Replacement: 9 단계, 이미지 1/2 Samsung Chromebook series 5 XE550C22 SSD Replacement: 9 단계, 이미지 2/2
    • Pull the SSD up and away from the Chromebook
결론
다른 4명이 해당 안내서를 완성하였습니다.
Abel Osorio
회원 가입일: 09/11/17
330 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team S2-G7, Bruce Fall 2017 CSU Fullerton, Team S2-G7, Bruce Fall 2017 회원
CSUF-BRUCE-F17S2G7
3 회원들
안내서 14개 작성하였습니다
댓글 4개
Hello where can I get I higher SSD to buy
aduboa moses - 답글
The SSD on the Chromebook 3 is non-upgradable. This is a different model. Please post this guide in the model you have.
frontiergds - 답글
If you want to get more storage out of your chromebook get a sd card and you will only need it if you have a chrultrabook.
Will F - 답글
The samsung chromebook shown on this guide is Samsung Chromebook XE550C22. The samsung chromebook 3 ( XE500C13 ), is totally different model. I have edited the title and description to match the actual model.
coldspring21 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 41
전체 시간: 5,094
