주요 콘텐츠로 건너뛰기
Samsung DV180F Repair Back control buttons Replacement
필요한 것
  1. Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: 1 단계, 이미지 1/2 Samsung DV180F Repair Back control buttons Replacement, Back Buttons Panel: 1 단계, 이미지 2/2
    • Ensure the camera is turned off and battery is taken out before you begin.
    • Remove the two external screws from the camera using a Phillips 000 screwdriver.
  2. Samsung DV180F Repair Back control buttons Replacement: 2 단계, 이미지 1/1
    • Insert a plastic opening tool in the gap between the camera body and back panel.
    • Pry along the right side of the camera to separate the back panel.
  3. Samsung DV180F Repair Back control buttons Replacement: 3 단계, 이미지 1/1
    • Once the camera is open, remove the two internal screws using a Phillips 000 screwdriver.
  4. Samsung DV180F Repair Back control buttons Replacement: 4 단계, 이미지 1/2 Samsung DV180F Repair Back control buttons Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to release the lock securing the ribbon receptor to the right side of the motherboard.
    • Ribbons have to be unlocked before removal to prevent damage.
  5. Samsung DV180F Repair Back control buttons Replacement: 5 단계, 이미지 1/1
    • Gently lift the circuit board from the camera.
    • Remove the display ribbon receptor lock to remove back panel from the motherboard.
  6. Samsung DV180F Repair Back control buttons Replacement: 6 단계, 이미지 1/2 Samsung DV180F Repair Back control buttons Replacement: 6 단계, 이미지 2/2
    • Remove back display.
    • Replace the back button panel.
결론
maria
회원 가입일: 09/26/16
244 평판
안내서 2개 작성하였습니다
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 353
