주요 콘텐츠로 건너뛰기
Samsung DV180F Repair Battery Replacement
필요한 것
  1. Samsung DV180F Repair Battery Replacement, Battery: 1 단계, 이미지 1/2 Samsung DV180F Repair Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Locate the battery door and slide it to the right to unlatch it. Swing the battery door up to expose the battery chamber.
    • Ensure that the camera is turned off before attempting to replace the battery.
  2. Samsung DV180F Repair Battery Replacement: 2 단계, 이미지 1/1
    • Locate the blue latch that holds the battery in the battery chamber. Using your fingernail or a plastic opening tool, push it away from the battery, in the direction of the arrow on the latch.
  3. Samsung DV180F Repair Battery Replacement: 3 단계, 이미지 1/2 Samsung DV180F Repair Battery Replacement: 3 단계, 이미지 2/2
    • Once the latch is disengaged, the battery should pop up. Grab the battery and slide it up and out of the camera.
  4. Samsung DV180F Repair Battery Replacement: 4 단계, 이미지 1/1
    • Move the blue latch out of the way and slide the replacement battery into the battery chamber. Lightly push until the battery clicks in place. Close the battery door.
    • Make sure that the replacement battery is oriented correctly.
결론
maria
회원 가입일: 09/26/16
244 평판
안내서 2개 작성하였습니다
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 411
