주요 콘텐츠로 건너뛰기
Samsung DV180F Repair Display Screen Replacement
필요한 것
  1. Samsung DV180F Repair Display Screen Replacement, Display Screen: 1 단계, 이미지 1/3 Samsung DV180F Repair Display Screen Replacement, Display Screen: 1 단계, 이미지 2/3 Samsung DV180F Repair Display Screen Replacement, Display Screen: 1 단계, 이미지 3/3
    • Use a pry tool to push the highlighted blue latch away from the battery in the direction of the arrow. Remove the battery.
    • Use the Phillips 000 Bit to remove all screws from the perimeter of the device. Set aside.
    • Use a small Plastic Opening Tool at the seam by the Micro USB plug. Separate the plastic case from the device.
  2. Samsung DV180F Repair Display Screen Replacement: 2 단계, 이미지 1/2 Samsung DV180F Repair Display Screen Replacement: 2 단계, 이미지 2/2
    • Remove the outer casing holding the back part of the camera together. Leave on the front casing.
    • Use a Phillips screwdriver to remove the two small screws holding the outer casing to the mother board.
    • Use the prying tool to unhook the casing from the plate covering the motherboard
  3. Samsung DV180F Repair Display Screen Replacement: 3 단계, 이미지 1/3 Samsung DV180F Repair Display Screen Replacement: 3 단계, 이미지 2/3 Samsung DV180F Repair Display Screen Replacement: 3 단계, 이미지 3/3
    • Release the ribbon from the button casing connected to the motherboard.
    • Hold the metal casing out of the way and snap the ribbon connector back. Remove the display screen ribbon attached.
    • Replace the screen then repeat all of these steps in reverse order to reassemble.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Evan McGettrick
회원 가입일: 09/24/16
190 평판
안내서 1개 작성함
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G4
4 회원들
안내서 8개 작성하였습니다
댓글 2개
I got it open in the hope of finding a screen ID. I can not find a replacement screen for the DV180F. do you know if the DV150 screen will work?
lrrpbill68 - 답글
im looking for a screen as well were you able to find a replacement?
Sidath Paranavithane -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 477
