주요 콘텐츠로 건너뛰기
Samsung DV300F Lens Replacement
필요한 것
  1. Samsung DV300F Lens Replacement, Front and Rear Casing: 1 단계, 이미지 1/3 Samsung DV300F Lens Replacement, Front and Rear Casing: 1 단계, 이미지 2/3 Samsung DV300F Lens Replacement, Front and Rear Casing: 1 단계, 이미지 3/3
    • Remove the two black 4.2 mm screws on the right side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the left side of the camera using a Phillips #0 screwdriver.
    • Remove the two black 4.2 mm screws on the bottom of the camera using a Phillips #0 screwdriver.
  2. Samsung DV300F Lens Replacement: 2 단계, 이미지 1/2 Samsung DV300F Lens Replacement: 2 단계, 이미지 2/2
    • Remove the back case of the camera carefully.
  3. Samsung DV300F Lens Replacement: 3 단계, 이미지 1/3 Samsung DV300F Lens Replacement: 3 단계, 이미지 2/3 Samsung DV300F Lens Replacement: 3 단계, 이미지 3/3
    • Remove the front case of the camera.
    • Remove the front LCD screen from the front case next to the lens.
  4. Samsung DV300F Lens Replacement, Back Button Control: 4 단계, 이미지 1/2 Samsung DV300F Lens Replacement, Back Button Control: 4 단계, 이미지 2/2
    • Remove the blue button control from its position next to the LCD screen.
    • Pull the ribbon cable to disconnect the blue button control from the camera.
  5. Samsung DV300F Lens Replacement, Back LCD Screen: 5 단계, 이미지 1/1
    • Remove the back LCD screen from its place carefully.
  6. Samsung DV300F Lens Replacement: 6 단계, 이미지 1/2 Samsung DV300F Lens Replacement: 6 단계, 이미지 2/2
    • Flip the black tab where the back LCD screen connects to the circuit board.
    • Pull the tape connection to disconnect the back LCD screen from the circuit board.
  7. Samsung DV300F Lens Replacement, Lens: 7 단계, 이미지 1/2 Samsung DV300F Lens Replacement, Lens: 7 단계, 이미지 2/2
    • Unscrew the 3 silver #0 Phillips 4.45mm screws from the circuit board cover
    • Remove the circuit board cover
  8. Samsung DV300F Lens Replacement: 8 단계, 이미지 1/2 Samsung DV300F Lens Replacement: 8 단계, 이미지 2/2
    • Flip the first black tab connecting the lens to the circuit board
    • Flip the second black tab connecting the lens to the circuit board
    • Push the lens out from the front to remove it from the camera
결론
다른 5명이 해당 안내서를 완성하였습니다.
Timothy Gordon
회원 가입일: 03/23/15
820 평판
안내서 5개 작성하였습니다
Baylor, Team 5-10, Williams Spring 2015 Baylor, Team 5-10, Williams Spring 2015 회원
BU-WILLIAMS-S15S5G10
3 회원들
안내서 10개 작성하였습니다
댓글 한 개
pourquoi ne pas aussi montrer comment demonter le lens de samsung dv300f
nouzalek - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 1,538
