주요 콘텐츠로 건너뛰기
Samsung DVD-HD850 Player Power Cord Replacement
필요한 것
  1. Samsung DVD-HD850 Player Power Cord Replacement, Cover: 1 단계, 이미지 1/1
    • with the front of the device facing you, turn the device 180 degrees so the back panel of the device is facing you
  2. Samsung DVD-HD850 Player Power Cord Replacement, Locate and remove screws: 2 단계, 이미지 1/1
    • locate the three (3) screws on the back panel of the device that are implanted in the device
    • to remove the screws, use the tool(s) listed above (right underneath the introduction) and twist the screws counter-clockwise to remove them from the device
  3. Samsung DVD-HD850 Player Power Cord Replacement, Remove Cover: 3 단계, 이미지 1/1
    • to remove the cover of the device, pull the cover towards the back of the device until it is completely removed so you can see the insides of the device
  4. Samsung DVD-HD850 Player Power Cord Replacement, Replacing the power cord: 4 단계, 이미지 1/2 Samsung DVD-HD850 Player Power Cord Replacement, Replacing the power cord: 4 단계, 이미지 2/2
    • Unclip the old power cord from the dual pin connector.
    • Once the old power cord has been unclipped take the new power cord and simply clip it in where the old one was.
  5. Samsung DVD-HD850 Player Power Cord Replacement, Adjust the wire: 5 단계, 이미지 1/2 Samsung DVD-HD850 Player Power Cord Replacement, Adjust the wire: 5 단계, 이미지 2/2
    • Adjust the rubber block on the power cord so that it fits in the slot on the back of the DVD player.
    • This makes it so that the cover panel will be able to slide back on.
결론
Robert Moss
회원 가입일: 10/22/14
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-6, Duarte Fall 2014 UMass Dartmouth, Team 1-6, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S1G6
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 413
