주요 콘텐츠로 건너뛰기
Samsung DVD-P230 Power Cord Replacement
필요한 것
  1. Samsung DVD-P230 Power Cord Replacement, Outer Cover & Faceplate: 1 단계, 이미지 1/3 Samsung DVD-P230 Power Cord Replacement, Outer Cover & Faceplate: 1 단계, 이미지 2/3 Samsung DVD-P230 Power Cord Replacement, Outer Cover & Faceplate: 1 단계, 이미지 3/3
    • Open the tray by pressing the eject button
    • Remove the DVD tray faceplate by pushing the faceplate up off of the tray.
    Very Super service!
    SzibeL - 답글
  2. Samsung DVD-P230 Power Cord Replacement: 2 단계, 이미지 1/1
    • Press the eject button to insert the tray
    • After the tray is closed unplug DVD player
  3. Samsung DVD-P230 Power Cord Replacement: 3 단계, 이미지 1/1
    • Unscrew the 3 screws in the back.
  4. Samsung DVD-P230 Power Cord Replacement: 4 단계, 이미지 1/2 Samsung DVD-P230 Power Cord Replacement: 4 단계, 이미지 2/2
    • Pull the outer case upward and then towards you.
  5. Samsung DVD-P230 Power Cord Replacement: 5 단계, 이미지 1/3 Samsung DVD-P230 Power Cord Replacement: 5 단계, 이미지 2/3 Samsung DVD-P230 Power Cord Replacement: 5 단계, 이미지 3/3
    • There are six symmetrically placed tabs holding in the front faceplate. Unhook these six tabs to loosen the faceplate.
  6. Samsung DVD-P230 Power Cord Replacement: 6 단계, 이미지 1/2 Samsung DVD-P230 Power Cord Replacement: 6 단계, 이미지 2/2
    • Pull off front faceplate. This may take a couple of tries to get all six tabs unhooked simultaneously.
  7. Samsung DVD-P230 Power Cord Replacement, Power Cord: 7 단계, 이미지 1/3 Samsung DVD-P230 Power Cord Replacement, Power Cord: 7 단계, 이미지 2/3 Samsung DVD-P230 Power Cord Replacement, Power Cord: 7 단계, 이미지 3/3
    • Locate the white clip that attaches the cord to the motherboard
    • Grasp clip and squeeze to release
    • Lift up and remove power cord
    • Slide cord mount from outer case
결론
다른 2명이 해당 안내서를 완성하였습니다.
Evan Domingue
회원 가입일: 01/28/11
410 평판
안내서 3개 작성하였습니다
Cal Poly, Team 3-30, Regan Winter 2011 Cal Poly, Team 3-30, Regan Winter 2011 회원
CPSU-REGAN-W11S3G30
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
where can I get a replacement cord?
Bill Cavanaugh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,154
