주요 콘텐츠로 건너뛰기
Samsung Droid Charge Battery Replacement
필요한 것
  1. Samsung Droid Charge Battery Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Open up the back case on the phone from the groove in the bottom of the phone.
    • You can do this by inserting a fingernail or similarly thin object into the groove and pulling up with mild force.
  2. Samsung Droid Charge Battery Replacement, Battery: 2 단계, 이미지 1/1
    • Below the left part of the bottom of the battery area there will be a groove large enough to fit in a finger or screw driver head.
    • Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Luke Gordon
회원 가입일: 09/26/12
178 평판
안내서 5개 작성하였습니다
Cal Poly, Team 15-44, Forte Fall 2012 Cal Poly, Team 15-44, Forte Fall 2012 회원
CPSU-FORTE-F12S15G44
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,626
