소개
This guide will show you how to remove the current screen on your Samsung Droid Charge and install a new one.
필요한 것
Use the groove to lever out the battery gently, in order to not damage either the battery or phone. Store the battery in a safe place.
Push the SD card further into its metal slot until you hear a click.
Release the card, and it should automatically eject itself.
Remove the SD card.
Locate the 7 small black screws located around the edge of the phone under the battery cover.
With a small Philips head screwdriver, remove each of the screws and place them in a secure location.
다른 5명이 해당 안내서를 완성하였습니다.
