소개
This guide details how to install a new power button into your Samsung Epic 4G. Directions are provided for both disassembly and reassembly.
필요한 것
Slide your fingernail along the edge of the device and pull at the plastic backing.
Locate the memory card on the upper right-hand corner of the device.
Remove the memory card from the device by gently sliding it out of its holder with your fingers.
Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
Remove the power button using tweezers if it did not fall out in the previous step.
다른 한 분이 해당 안내서를 완성하였습니다.
