이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide details how to install a new power button into your Samsung Epic 4G. Directions are provided for both disassembly and reassembly.
필요한 것
Slide your fingernail along the edge of the device and pull at the plastic backing.
Remove the memory card from the device by gently sliding it out of its holder.
Remove the seven screws from the back of the phone using the Phillips screwdriver.
Separate the back housing from the silver trim around the phone using a nylon spudger.
If it did not fall out in the previous step, remove the power button using tweezers.
다른 한 분이 해당 안내서를 완성하였습니다.
