주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Epic 4G Touch Battery Replacement
필요한 것
    1. Samsung Epic 4G Touch Battery Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Samsung Epic 4G Touch Battery Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
      • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
      • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
      댓글 쓰기
    2. Samsung Epic 4G Touch Battery Replacement: 2 단계, 이미지 2개 중 1개 Samsung Epic 4G Touch Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Lift and remove the rear case.
      댓글 쓰기
    1. Samsung Epic 4G Touch Battery Replacement, Battery: 3 단계, 이미지 2개 중 1개 Samsung Epic 4G Touch Battery Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
      • Push the plastic opening tool downward to pry the battery up from its housing.
      댓글 쓰기
    2. Samsung Epic 4G Touch Battery Replacement: 4 단계, 이미지 2개 중 1개 Samsung Epic 4G Touch Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Lift and remove the battery from the midframe.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Walter Galan
711,029 평판
안내서 1,203개를 작성함
2가이드 댓글
i just reacently got my phone and I don't know whats happening to it. it keeps turning itself off. iv factory reset it 2 times. should I replace the phone or just the battery. I have a Samsung galaxy s II. (sprint)
gamerzzz - 답글 공유
I have an samsung galaxy s2 gsm unlocked and my battery wont stay charge and sometimes when its plugged in a charger it decreases instead of increasing and if it does charges it decrease fast what shall i do shall i get a new battery or replace the phone
ianasims - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 28
지난 30일: 65
전체 시간: 10,461
