주요 콘텐츠로 건너뛰기
Samsung Epic 4G Touch Battery Replacement
필요한 것
  1. Samsung Epic 4G Touch Battery Replacement, Rear Case: 1 단계, 이미지 1/2 Samsung Epic 4G Touch Battery Replacement, Rear Case: 1 단계, 이미지 2/2
    • Insert a plastic opening tool, or your fingernail, into the opening near the left side of the headphone jack.
    • Pry the opening tool downward to pop the rear case from its clips securing it to the the midframe.
  2. Samsung Epic 4G Touch Battery Replacement: 2 단계, 이미지 1/2 Samsung Epic 4G Touch Battery Replacement: 2 단계, 이미지 2/2
    • Lift and remove the rear case.
  3. Samsung Epic 4G Touch Battery Replacement, Battery: 3 단계, 이미지 1/2 Samsung Epic 4G Touch Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Wedge a plastic opening tool into the crevice between the battery and midframe located near the bottom left corner.
    • Push the plastic opening tool downward to pry the battery up from its housing.
  4. Samsung Epic 4G Touch Battery Replacement: 4 단계, 이미지 1/2 Samsung Epic 4G Touch Battery Replacement: 4 단계, 이미지 2/2
    • Lift and remove the battery from the midframe.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Walter Galan
694,692 평판
안내서 1,203개 작성하였습니다
댓글 2개
i just reacently got my phone and I don't know whats happening to it. it keeps turning itself off. iv factory reset it 2 times. should I replace the phone or just the battery. I have a Samsung galaxy s II. (sprint)
gamerzzz - 답글
I have an samsung galaxy s2 gsm unlocked and my battery wont stay charge and sometimes when its plugged in a charger it decreases instead of increasing and if it does charges it decrease fast what shall i do shall i get a new battery or replace the phone
ianasims - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 9,702
