주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Epic 4G Touchscreen Replacement
필요한 것
    1. Samsung Epic 4G Touchscreen Replacement, Phone Case: 1 단계, 이미지 1개 중 1개
      • Slide your fingernail along the edge of the device and pull at the plastic backing.
      • While pulling the plastic backing apart from the device, you will hear a snap sound which signals that the backing has detached.
      댓글 쓰기
    2. Samsung Epic 4G Touchscreen Replacement: 2 단계, 이미지 1개 중 1개
      • Pull at the plastic backing gently to remove it after hearing the snap sound.
      댓글 쓰기
    1. Samsung Epic 4G Touchscreen Replacement, Battery: 3 단계, 이미지 1개 중 1개
      • Remove the battery from the device by pulling the battery edge upwards.
      댓글 쓰기
    1. Samsung Epic 4G Touchscreen Replacement, Removing the Memory Card:: 4 단계, 이미지 1개 중 1개
      • Locate the memory card on the upper right-hand corner of the device.
      • Remove the memory card from the device by gently sliding it out of its holder with your fingers.
      댓글 쓰기
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Back Housing: 5 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Back Housing: 5 단계, 이미지 2개 중 2개
      • Remove the seven screws from the back of the phone using the Phillips #000 screwdriver.
      • Separate the backing from the silver trim around the phone by using a nylon spudger to pry between the two components.
      • While separating the two components, most of the buttons (including the power button) will fall out.
      댓글 쓰기
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Power Button: 6 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Power Button: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the power button using tweezers if it did not fall out in the previous step.
      • At this point, you can replace the power button with a new one from a manufacturer.
      댓글 쓰기
    1. Samsung Epic 4G Touchscreen Replacement, Micro USB Port: 7 단계, 이미지 1개 중 1개
      • Remove the white cable along the right side of the device (next to the battery housing) using the nylon spudger.
      • Pull out both ends of the white cable. They will easily snap out of place without excessive tension.
      • Do not rip the white cables out of the device.
      댓글 쓰기
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Antenna Assembly: 8 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Antenna Assembly: 8 단계, 이미지 2개 중 2개
      • Remove the screw holding the antenna assembly in place using a Tri-Point Y0 screwdriver.
      • Snap the antenna assembly out of the device gently using your fingers.
      댓글 쓰기
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable: 9 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable: 9 단계, 이미지 2개 중 2개
      • Pry the flex cable from the top of the phone by carefully using a nylon spudger.
      • Repeat this step for the larger flex cable located on the left side of the device below the smaller one.
      댓글 쓰기
    4. Samsung Epic 4G Touchscreen Replacement: 10 단계, 이미지 1개 중 1개
      • Lift and remove the motherboard from the device.
      • The USB port is located at the top of the motherboard. At this point, replace the port with a new one from a manufacturer.
      댓글 쓰기
    1. Samsung Epic 4G Touchscreen Replacement, Camera Lens: 11 단계, 이미지 1개 중 1개
      • Remove and replace the camera lens with a new one from a manufacturer.
      댓글 쓰기
    1. Samsung Epic 4G Touchscreen Replacement, Keyboard: 12 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Keyboard: 12 단계, 이미지 2개 중 2개
      • Remove the white label sticker.
      • Remove the four screws on the left side of the device with a small Phillips screwdriver.
      • Two of the screws are found behind the white label, and two are found directly above the label.
      댓글 쓰기
    2. Samsung Epic 4G Touchscreen Replacement: 13 단계, 이미지 3개 중 1개 Samsung Epic 4G Touchscreen Replacement: 13 단계, 이미지 3개 중 2개 Samsung Epic 4G Touchscreen Replacement: 13 단계, 이미지 3개 중 3개
      • Lift up and loosen the metallic silver trim on the perimeter of the phone using a nylon spudger.
      • Carefully remove the gray mid-plate with the spudger.
      • Take extra caution to not destroy the QWERTY keyboard, which lies directly behind the mid-plate. Do not slide open the phone at this time.
      • The mid-plate should be completely removed from the keyboard and separated from the device.
      • At this point, you may remove the original QWERTY keyboard and install a replacement keyboard. Installation is the reverse of removal.
      댓글 쓰기
    1. Samsung Epic 4G Touchscreen Replacement, Removing the Keypad Housing:: 14 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Keypad Housing:: 14 단계, 이미지 2개 중 2개
      • Remove the four Phillips #00 screws on the keypad housing.
      • Carefully pull off the keypad housing while avoiding the flex cable.
      댓글 쓰기
    2. Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism:: 15 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism:: 15 단계, 이미지 2개 중 2개
      • Remove the two black screw covers using the spudger.
      • Carefully unscrew the four corner screws using the Phillips screwdriver.
      댓글 쓰기
    3. Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism (continued):: 16 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Slide Mechanism (continued):: 16 단계, 이미지 2개 중 2개
      • Pry off the slide mechanism using the flat edge of the spudger.
      • Be careful not to push the spudger too far in since it can damage the phone.
      • Carefully separate the slide mechanism while avoiding the flex cable.
      댓글 쓰기
    4. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: 17 단계, 이미지 3개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: 17 단계, 이미지 3개 중 2개 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable:: 17 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Carefully remove all the blue tape using the tweezers.
      • Unsnap and pull out the large portion of the flex cable.
      • Pull off the front face camera using the tweezers.
      댓글 쓰기
    5. Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: 18 단계, 이미지 3개 중 1개 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: 18 단계, 이미지 3개 중 2개 Samsung Epic 4G Touchscreen Replacement, Removing the Flex Cable (continued):: 18 단계, 이미지 3개 중 3개
      • Carefully pull out the smaller portion of the flex cable using the tweezers.
      • Pop out the last part of the flex cable using the flat edge of the spudger.
      • Remove the flex cable completely.
      댓글 쓰기
    6. Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: 19 단계, 이미지 3개 중 1개 Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: 19 단계, 이미지 3개 중 2개 Samsung Epic 4G Touchscreen Replacement, Separating the Screen:: 19 단계, 이미지 3개 중 3개
      • Pull out the touch sensor flex cable using the tweezers.
      • Fold back the strip of white tape using the tweezers.
      • Pop out the speaker assembly using the spudger.
      댓글 쓰기
    7. Samsung Epic 4G Touchscreen Replacement, Separating the Screen (continued):: 20 단계, 이미지 2개 중 1개 Samsung Epic 4G Touchscreen Replacement, Separating the Screen (continued):: 20 단계, 이미지 2개 중 2개
      • Carefully pull apart the frame and the screen.
      • You can now replace the LCD screen.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Andrew Cunningham
회원 가입일: 10/03/12
273 평판
안내서 6개를 작성함
Cal Poly, Team 24-25, Regan Fall 2012 Cal Poly, Team 24-25, Regan Fall 2012 회원
CPSU-REGAN-F12S24G25
4 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 5,479
