주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Step-by-step guild to replacing your old worn out keyboard buttons.
부품
지정된 부품이 없습니다.
  1. Press button on back of phone below camera.
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by sliding off (not shown in picture).
  2. Grasp the battery near the bottom with two fingers.
    • Grasp the battery near the bottom with two fingers.
    • Lift battery up and out gently.
  3. Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • Use the Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips. There are three clips on each side and two at the bottom of the phone.
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable located in the bottom right side of the motherboard.
  7. Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Using an iPod opening tool, unlatch the ribbon cable located in the lower right corner of the motherboard.
    • Carefully remove the ribbon.
  8. Remove the front faceplate.
    • Remove the front faceplate.
  9. Grasp the rubber keyboard in the corner with your fingers and lift to remove.
    • Grasp the rubber keyboard in the corner with your fingers and lift to remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris
회원 가입일: 2011년 04월 20일
23 평판
안내서 1개 작성함
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 회원
CPSU-REGAN-S11S15G15
5 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 1,579
