주요 콘텐츠로 건너뛰기
Samsung Epix LCD Display Replacement
필요한 것
  1. Samsung Epix LCD Display Replacement, Battery: 1 단계, 이미지 1/1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix LCD Display Replacement: 2 단계, 이미지 1/1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix LCD Display Replacement, LCD Display: 3 단계, 이미지 1/1
    • Remove the rubber screw cover in the top left corner by prying upwards with an opening tool.
  4. Samsung Epix LCD Display Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone.
    • The upper right screw is 4.5 mm and the others are 6.5 mm.
  5. Samsung Epix LCD Display Replacement: 5 단계, 이미지 1/2 Samsung Epix LCD Display Replacement: 5 단계, 이미지 2/2
    • Slide the opening tool along the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix LCD Display Replacement: 6 단계, 이미지 1/1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It will still be connected to the phone chassis by a ribbon cable on the motherboard.
  7. Samsung Epix LCD Display Replacement: 7 단계, 이미지 1/1
    • Using an opening tool, undo the ZIF connector halfway up the right side.
    • Carefully remove ribbon cable.
  8. Samsung Epix LCD Display Replacement: 8 단계, 이미지 1/1
    • Remove the front faceplate by lifting it off of the phone chassis.
  9. Samsung Epix LCD Display Replacement: 9 단계, 이미지 1/1
    • Using the opening tool, unlatch the LCD ribbon cable.
  10. Samsung Epix LCD Display Replacement: 10 단계, 이미지 1/1
    • Using an opening tool or spudger, pry under the lower left and right corners of the LCD screen.
    • The LCD is held in place to the chassis with adhesive strips.
    • Do not pry excessively hard. You may damage the circuitry on the back of the LCD.
  11. Samsung Epix LCD Display Replacement: 11 단계, 이미지 1/1
    • Lift the LCD display out from phone chassis.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mark Wyse
회원 가입일: 04/19/11
59 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 회원
CPSU-REGAN-S11S15G15
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,893
