주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Epix Motherboard Replacement
필요한 것
    1. Samsung Epix Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Just below the phone's camera, press the button and hold it
      • While the button is held down, slide the back panel off to remove it completely.
      댓글 쓰기
    2. Samsung Epix Motherboard Replacement: 2 단계, 이미지 1개 중 1개
      • Grasp the bottom corners of the battery with two fingers and gently lift.
      • Gently lift the battery and remove it from the phone.
      댓글 쓰기
    1. Samsung Epix Motherboard Replacement, Speakers: 3 단계, 이미지 1개 중 1개
      • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
      댓글 쓰기
    2. Samsung Epix Motherboard Replacement: 4 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
      • The upper right screw is 4.5mm while the rest are 6.5mm.
      댓글 쓰기
    3. Samsung Epix Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Samsung Epix Motherboard Replacement: 5 단계, 이미지 2개 중 2개
      • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
      • There are three clips on each side and two at the bottom of the phone.
      댓글 쓰기
    4. Samsung Epix Motherboard Replacement: 6 단계, 이미지 1개 중 1개
      • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
      • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
      댓글 쓰기
    5. Samsung Epix Motherboard Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
      • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
      댓글 쓰기
    6. Samsung Epix Motherboard Replacement: 8 단계, 이미지 1개 중 1개
      • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
      댓글 쓰기
    7. Samsung Epix Motherboard Replacement: 9 단계, 이미지 1개 중 1개
      • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
      • Lift the speaker off of the motherboard.
      • The camera will remain attached to the phone when removing the speaker.
      댓글 쓰기
    1. Samsung Epix Motherboard Replacement, Motherboard: 10 단계, 이미지 1개 중 1개
      • Using an iFixit opening tool, unlatch and disconnect the camera ribbon cable.
      댓글 쓰기
    2. Samsung Epix Motherboard Replacement: 11 단계, 이미지 1개 중 1개
      • Unlatch the LCD ribbon cable on the left side of the motherboard using the opening tool.
      댓글 쓰기
    3. Samsung Epix Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Samsung Epix Motherboard Replacement: 12 단계, 이미지 2개 중 2개
      • Unlatch and disconnect the two ribbon cables at the bottom center of the motherboard.
      • The two disconnected ribbon cables connect to the keypad and center button.
      댓글 쓰기
    4. Samsung Epix Motherboard Replacement: 13 단계, 이미지 1개 중 1개
      • Unlatch and remove the front panel ribbon cable located at the bottom right of the motherboard.
      댓글 쓰기
    5. Samsung Epix Motherboard Replacement: 14 단계, 이미지 1개 중 1개
      • Use the opening tool to gently disconnect the microphone cable, also located at the bottom right of the motherboard.
      댓글 쓰기
    6. Samsung Epix Motherboard Replacement: 15 단계, 이미지 1개 중 1개
      • Using a Phillips #00 screwdriver, remove the 3.5 mm screw at the bottom center of the motherboard.
      댓글 쓰기
    7. Samsung Epix Motherboard Replacement: 16 단계, 이미지 1개 중 1개
      • Carefully lift the motherboard from the left side to begin removing it from the phone chassis.
      • A ribbon cable is still connected underneath on the right side.
      댓글 쓰기
    8. Samsung Epix Motherboard Replacement: 17 단계, 이미지 1개 중 1개
      • Flip the motherboard slightly to access the back, then use the opening tool to unlatch and disconnect the remaining ribbon cable.
      • Remove the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Mark Wyse
회원 가입일: 04/19/11
62 평판
안내서 2개를 작성함
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 회원
CPSU-REGAN-S11S15G15
5 회원들
안내서 35개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 36
전체 시간: 1,993
