주요 콘텐츠로 건너뛰기
Samsung Epix Motherboard Replacement
필요한 것
  1. Samsung Epix Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Press button on back of phone below camera.
    • While button is depressed, remove the back panel of the phone by it sliding off (not shown in picture).
  2. Samsung Epix Motherboard Replacement: 2 단계, 이미지 1/1
    • Grasp the bottom corners of the battery with two fingers and gently lift.
  3. Samsung Epix Motherboard Replacement, Speakers: 3 단계, 이미지 1/1
    • Using an iPod opening tool, remove the screw cover in the top left corner by lifting it up.
  4. Samsung Epix Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the six screws on the back of the phone. Three are evenly spaced on each side.
    • The upper right screw is 4.5mm while the rest are 6.5mm.
  5. Samsung Epix Motherboard Replacement: 5 단계, 이미지 1/2 Samsung Epix Motherboard Replacement: 5 단계, 이미지 2/2
    • Slide the iPod opening tool into the seam on the side of the phone and turn it slightly to unhook the eight clips.
    • There are three clips on each side and two at the bottom of the phone.
  6. Samsung Epix Motherboard Replacement: 6 단계, 이미지 1/1
    • Once all eight of the clips have been unhooked, lift the back panel off of the phone.
    • Be careful not to remove the front panel. It is still connected to the phone chassis by a ribbon cable in the bottom right corner of the motherboard.
  7. Samsung Epix Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the circular battery from the plastic holder by inserting a 1 mm flat head screwdriver under the battery where the red and blue wires connect and lifting gently.
    • Make sure the battery is still connected to the motherboard via the red and blue wires. This part does not have to be completely removed.
  8. Samsung Epix Motherboard Replacement: 8 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, unscrew the two 3.5mm screws that connect the speaker to the motherboard.
  9. Samsung Epix Motherboard Replacement: 9 단계, 이미지 1/1
    • With the iPod opening tool, unclip the red and black wires connecting the speaker to the motherboard.
    • Lift the speaker off of the motherboard.
    • The camera will remain attached to the phone when removing the speaker.
  10. Samsung Epix Motherboard Replacement, Motherboard: 10 단계, 이미지 1/1
    • Using iPod opener tool, unlatch and remove the camera ribbon cable.
  11. Samsung Epix Motherboard Replacement: 11 단계, 이미지 1/1
    • Using iPod opener tool, unlatch LCD ribbon cable on left side of motherboard.
  12. Samsung Epix Motherboard Replacement: 12 단계, 이미지 1/2 Samsung Epix Motherboard Replacement: 12 단계, 이미지 2/2
    • Using iPod opener tool, unlatch and remove the two ribbon cables at the bottom center of motherboard for the keypad and center button.
  13. Samsung Epix Motherboard Replacement: 13 단계, 이미지 1/1
    • Using iPod opener tool, unlatch and remove the front panel ribbon cable at bottom right of motherboard.
  14. Samsung Epix Motherboard Replacement: 14 단계, 이미지 1/1
    • Using the iPod opener tool, remove the microphone cable at bottom right of motherboard.
  15. Samsung Epix Motherboard Replacement: 15 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm screw at the bottom center of motherboard.
  16. Samsung Epix Motherboard Replacement: 16 단계, 이미지 1/1
    • Carefully lift motherboard off of phone chassis starting on the left side.
    • There is one ribbon cable still attached underneath the motherboard on the right side.
  17. Samsung Epix Motherboard Replacement: 17 단계, 이미지 1/1
    • Using iPod opener tool, unlatch and remove ribbon cable on back side of motherboard.
    • Remove the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mark Wyse
회원 가입일: 04/19/11
59 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-15, Regan Spring 2011 Cal Poly, Team 15-15, Regan Spring 2011 회원
CPSU-REGAN-S11S15G15
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,558
