주요 콘텐츠로 건너뛰기
Samsung Eternity Camera Replacement
필요한 것
    • Remove the back battery cover.
  1. Samsung Eternity Camera Replacement: 2 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the phone's battery.
  2. Samsung Eternity Camera Replacement: 3 단계, 이미지 1/1
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver
  3. Samsung Eternity Camera Replacement: 4 단계, 이미지 1/2 Samsung Eternity Camera Replacement: 4 단계, 이미지 2/2
    • Continuing to use the Phillips #00 screwdriver, gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Camera Replacement, Camera: 5 단계, 이미지 1/1
    • Peel off the Identification sticker.
  5. Samsung Eternity Camera Replacement: 6 단계, 이미지 1/1
    • Peel the button sensor on the side of the motherboard off of the case.
  6. Samsung Eternity Camera Replacement: 7 단계, 이미지 1/1
    • Pop the black hinged-release lever toward its ribbon, then slide the ribbon out.
  7. Samsung Eternity Camera Replacement: 8 단계, 이미지 1/1
    • Peel up the camera attachment.
  8. Samsung Eternity Camera Replacement: 9 단계, 이미지 1/1
    • You will now be able to replace the Camera component with a new part.
결론
Michelle Haddock
회원 가입일: 04/20/11
45 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 회원
CPSU-REGAN-S11S15G11
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,784
