주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Eternity Microphone Replacement
필요한 것
    • Remove the back battery cover.
  1. Samsung Eternity Microphone Replacement: 2 단계, 이미지 1개 중 1개
    • Using a nylon spudger, remove the phone's battery.
  2. Samsung Eternity Microphone Replacement: 3 단계, 이미지 1개 중 1개
    • Remove six (4.28 x 1.25)mm screws using the Phillips #00 screwdriver.
  3. Samsung Eternity Microphone Replacement: 4 단계, 이미지 2개 중 1개 Samsung Eternity Microphone Replacement: 4 단계, 이미지 2개 중 2개
    • Use a nylon spudger to gently pry the silver plastic back plate from the body of the phone.
  4. Samsung Eternity Microphone Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    • It is very easy to rip motherboard cables and damage fragile motherboard clips. Be careful when you are removing every component.
    • Pull the antenna plug out of its socket.
  5. Samsung Eternity Microphone Replacement: 6 단계, 이미지 3개 중 1개 Samsung Eternity Microphone Replacement: 6 단계, 이미지 3개 중 2개 Samsung Eternity Microphone Replacement: 6 단계, 이미지 3개 중 3개
    • Pop the two black hinged-release levers toward their ribbons, then slide the ribbons out.
  6. Samsung Eternity Microphone Replacement: 7 단계, 이미지 1개 중 1개
    • Pop the red hinged-release lever away from its ribbon. Then pull it out.
  7. Samsung Eternity Microphone Replacement: 8 단계, 이미지 1개 중 1개
    • Peel the button sensor on the side of the motherboard off of the case.
  8. Samsung Eternity Microphone Replacement: 9 단계, 이미지 3개 중 1개 Samsung Eternity Microphone Replacement: 9 단계, 이미지 3개 중 2개 Samsung Eternity Microphone Replacement: 9 단계, 이미지 3개 중 3개
    • Slightly pull up one side of the motherboard.
    • Pull the button/microphone plug out of its socket.
    • Pop the red hinged-release lever away from its ribbon, then slide the ribbon out.
  9. Samsung Eternity Microphone Replacement: 10 단계, 이미지 1개 중 1개
    • You have successfully removed the motherboard from the phone.
  10. Samsung Eternity Microphone Replacement, Digitizer and Screen: 11 단계, 이미지 1개 중 1개
    • Flip the phone over so you are looking at the front screen of the phone.
  11. Samsung Eternity Microphone Replacement: 12 단계, 이미지 3개 중 1개 Samsung Eternity Microphone Replacement: 12 단계, 이미지 3개 중 2개 Samsung Eternity Microphone Replacement: 12 단계, 이미지 3개 중 3개
    • Use a small tool to pry the digitizer and screen (together) from the frame of the phone.
    • This may take some time and careful work because it is glued down to the frame.
    • Be careful when you pull the lower part of this piece away from the phone frame because there is a ribbon attached to the digitizer that you don't want to break. There is also a ribbon on the side of the screen to be aware of.
  12. Samsung Eternity Microphone Replacement: 13 단계, 이미지 3개 중 1개 Samsung Eternity Microphone Replacement: 13 단계, 이미지 3개 중 2개 Samsung Eternity Microphone Replacement: 13 단계, 이미지 3개 중 3개
    • Next, carefully pull the digitizer away from the screen.
    • At this point you can replace either the screen or the digitizer.
    • Cleaning the screen with a glass cleaning cloth before reassembling will remove any smudges or fingerprints from disassembling the device.
  13. Samsung Eternity Microphone Replacement, Microphone: 14 단계, 이미지 1개 중 1개
    • Pop the microphone up and out of its small housing.
  14. Samsung Eternity Microphone Replacement: 15 단계, 이미지 1개 중 1개
    • Peel up the black tape on the bottom of the back case.
  15. Samsung Eternity Microphone Replacement: 16 단계, 이미지 1개 중 1개
    • Use the spudger to release the front buttons from the phones frame.
    • Don't try and pull the front buttons completely away from the phone. There are clips that still are holding them to the phone.
  16. Samsung Eternity Microphone Replacement: 17 단계, 이미지 3개 중 1개 Samsung Eternity Microphone Replacement: 17 단계, 이미지 3개 중 2개 Samsung Eternity Microphone Replacement: 17 단계, 이미지 3개 중 3개
    • Use the spudger to remove three plastic lasso hooks that are holding the front buttons to the case.
    • The front button plastic assembly should come right off.
  17. Samsung Eternity Microphone Replacement: 18 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to release the button logic board away from the phone's casing.
    • Do not try and completely remove the component. There are logic ribbons that need to be guided through the phone's back casing.
  18. Samsung Eternity Microphone Replacement: 19 단계, 이미지 1개 중 1개
    • You should be able to see two cables connected to the front button board.
    • Carefully slide these two cables through their respective holes in the body of the camera.
  19. Samsung Eternity Microphone Replacement: 20 단계, 이미지 1개 중 1개
    • The front button board should slide out. At this time you can replace the button/microphone component.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Michelle Haddock
회원 가입일: 04/20/11
51 평판
안내서 3개를 작성함
Cal Poly, Team 15-11, Regan Spring 2011 Cal Poly, Team 15-11, Regan Spring 2011 회원
CPSU-REGAN-S11S15G11
5 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 42
전체 시간: 2,404
