주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Exhibit II 4G Motherboard Replacement
필요한 것
  1. Samsung Exhibit II 4G Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Insert plastic opening tool under back cover.
    • Apply pressure on tool while using a downward motion to pop off back cover.
  2. Samsung Exhibit II 4G Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Insert plastic opening tool under battery.
    • Pry battery out.
  3. Samsung Exhibit II 4G Motherboard Replacement, Top Rear Housing Cover: 3 단계, 이미지 1개 중 1개
    • Pry the top cover upward to remove it from the phone.
  4. Samsung Exhibit II 4G Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the top cover.
  5. Samsung Exhibit II 4G Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Samsung Exhibit II 4G Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 3.8mm Phillips #000 screws securing the top cover to the back assembly.
    • Two screws from top and two screws from back.
  6. Samsung Exhibit II 4G Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Samsung Exhibit II 4G Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Samsung Exhibit II 4G Motherboard Replacement: 6 단계, 이미지 3개 중 3개
    • Insert plastic opening tool under top cover.
    • Using hand slide top cover away from phone.
  7. Samsung Exhibit II 4G Motherboard Replacement, Midframe: 7 단계, 이미지 1개 중 1개
    • Remove the four 3.8mm Phillips #000 screws securing the back assembly to the phone.
  8. Samsung Exhibit II 4G Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Insert plastic opening tool between back assembly and phone.
    • Pry the back assembly away from phone.
  9. Samsung Exhibit II 4G Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • With plastic opening tool continue prying around the edge of the back assembly.
  10. Samsung Exhibit II 4G Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Pull back panel assembly away from main body.
  11. Samsung Exhibit II 4G Motherboard Replacement, Vibration Motor: 11 단계, 이미지 2개 중 1개 Samsung Exhibit II 4G Motherboard Replacement, Vibration Motor: 11 단계, 이미지 2개 중 2개
    • Insert the pointed end of a spudger into the gap in the round housing frame.
    • Using spudger to remove vibrator remove from the adhesive.
  12. Samsung Exhibit II 4G Motherboard Replacement: 12 단계, 이미지 2개 중 1개 Samsung Exhibit II 4G Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to remove vibrator cable from motherboard.
  13. Samsung Exhibit II 4G Motherboard Replacement, Rear Facing Camera: 13 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to disconnect the camera assembly cable.
  14. Samsung Exhibit II 4G Motherboard Replacement: 14 단계, 이미지 2개 중 1개 Samsung Exhibit II 4G Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Remove camera from square housing.
  15. Samsung Exhibit II 4G Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 1개 Samsung Exhibit II 4G Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 2개 Samsung Exhibit II 4G Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 3개
    • Insert the spudger under each corner ribbon cable and lift them out of the way.
    • Use care when lifting the ribbon cables.
    • Insert a plastic pry tool into the gap between motherboard and base of phone
  16. Samsung Exhibit II 4G Motherboard Replacement: 16 단계, 이미지 3개 중 1개 Samsung Exhibit II 4G Motherboard Replacement: 16 단계, 이미지 3개 중 2개 Samsung Exhibit II 4G Motherboard Replacement: 16 단계, 이미지 3개 중 3개
    • Tilt the motherboard up carefully.
    • Be sure not to damage the ribbon cable still connected at the bottom of the motherboard.
    • Use a spudger to pry the connector from the socket on the motherboard.
    • Lift motherboard from frame.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
David R
회원 가입일: 07/20/15
1,152 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 38
전체 시간: 877
